I have done research on this site concerning the CR9E-stock replacement and the CR9EK-two ground electrodes. Many have stated that the CR9EK will give a slight HP increase over the stock CR9E replacement. This is not true according to NGK's website where I found this from:
"It is important to note that multi-ground does not mean multi-spark, there will still only be one spark at a time. Therefore a multi-ground plug will not perform any better and may actually perform worse than a traditional plug, unless the engine is designed for a multiple ground plug."
So after reading that I went and searched for the best price on the stock replacement plug and found this site:
http://www.clubplug.net/retail_complete_ngk.html
Look for cr9e and you will see that they are only $2.19!!!!!!!
Hope this helps anyone in the near future since many will be doing winter maintenance.
