1 - 12 of 12 Posts
If someone has their torque numbers from a dyno run in 250 RPM increments from 10,000-Redline I could tell you when to shift exactly, with a graph too! Until I get these numbers redline 1st through 3rd. Shift to 5th and 6th aroun 13,500.
bump, anyone have their torque numbers from a dyno run in 250 RPM increments from 10,000-Redline? Please post for 2005-06 ZX-6R and modifications if any.
Depends on your gearing and how many shifts you're making. You might want to bang it to the rev limiter, you might want to shift 500-800 rpm early to avoid the power fall off. But probably take it to the redline.
[:Agree]
On some dynos in the mags a stock 6R makes max hp around 13000 rpm and max torque around 11000 rpm.
1 - 12 of 12 Posts
