1 - 2 of 2 Posts
Most of the time my bike shifts fine. But-
Sometimes when I downshift fast and/or downshift two or more gears before letting out the clutch, the shifter gets kinda hung up. It will go into a false neutral and it won't downshift anymore. (You can push the lever down, and it returns, but it doesn't do anything.) So, to clear up the problem I upshift it. This gets it back into gear with a BANG. But I'm not sure which gear it goes back into.
This happens just once in a while and I have been riding this bike for over 3 years now. And I've finally decided to investigate. I plan on taking out the clutch & shift linkage and check it all out. Might be hard to figure this out though, since it doesn't always do it.
Anyone else got any ideas?
Thanks
charger_john
alot of times it can be the rider and sloppy shifting habbits.....the shift lever position in relation to your foot is key for consistent solid shifts!!
the 05/06 can benefit from the Factory PRO shifter kit, expensive but can be worth the investment.
1 - 2 of 2 Posts
