OK, I have the integrator all hooked up but I have a problem...the rear hazards don't work. I have replaced the relay, which solved the fast blinking, but the rear hazards only work if I hit the brakes. If I don't hit the brakes then only he front ones come on. Any ideas? Did I hook something up wrong?
You keep campaining for that ass-whooping you might get elected
The hazards were functioning the same way before and after the relay. The relay only solved the fast blinking problem. did you hook up the integrator to the blue or red wires on the tail light? I hooked mine to the blue. Maybe that's the problem?
