What I did first was dremel out a little bit near the back of the turn signal opening to make a better fit for the light. Then I took an extra long screw and drilled it into the screw hole of the light making sure it was long enough to go through the bodywork and hold. I applied the two sided tape after putting the screw through the signal, then applied to the body and screwed in to the fairing. Seems to be working fine for me.
