Slow wheelies
1915 Views 18 Replies 7 Participants Last post by  TommyV
1st
Keep in mind, the slower you're going the more likely you are to loop it. 90% of the wheelie accidents I've seen have been from doing a wheelie from a dead stop. Going slow gives you less screw up time. I think I start my wheelies about 25 or 30, so this seems about right.
Dan...comfortable enough with his manhood to ride a 600.
1 - 19 of 19 Posts
20-30 is fast! I'm 1 down 10 up and have no problem keeping them under 10 mph. Could do it with less drastic gearing no prob though.
Does anyone know whats the perfect gear for slow wheelies Im talkin real slow like 20 - 30 mph
"If your not lent over you might as well be bent over!"
I am using a renthal 14 tooth front and stock rear. The rest of the bike is bone stock too.[xx(]
That messes up your speedo though, doesn't it?
You gota have balls like these to drive a bike!
See less See more
Yea the damn thing makes me think Im going so much more faster then I actually am. I just stay with the flow of traffic or hoever else I am riding with. The Total throw off isnt to bad My buddy was going about 45 and I thought I was going 50 It gets just gets worse at higher speeds.
Buy one of those speedo error correcting boxes
See less See more
I haven't even hooked up my speedo since I got my sprockets. It would be so far off it would be funny!
I'll try and get a pic of my sprocket sometime. It looks so bling bling when the light shines off it [:p]
I know that this is a newbie question PimP, but when you say one down, 10 up, do you mean your front sprocket is a tooth smaller, and your back sprocket is 10 bigger?
-keep the rubber side down.[}:)]
Hey Sniper where can I find something like that? I have never even herd of one of those before.
It's called a yellow box. Eltorito mentioned it in another thread.
The website is www.blackrobotics.com
See less See more
You got it! :D
Damn man, your bike is definitely not set up for high speed highway getaways then, huh?:D
The guy I bought my bike from told me that he put a one tooth smaller sprocket on the front, and the back is a 42 tooth (of course, I can see the back one, not the front). I have topped my bike out at redline in sixth gear at about 142mph indicated. Also, when we go on rides through fast twisties, I can leave my bike in fifth gear, and still power out of corners hard enough to keep up. To me, this seems weird. I am always looking for seventh gear on my bike.:D
I'm considering going back to stock sprockets since my chain is almost at the end of its life. On the other hand, I don't want to not be able to do wheelies anymore. What do you think PimP?
Right now, 1st gear is good for about 30-35mph, and that's it, so when I wheelie, it is usuall at incredibly slow speed. A friend of mine has a CBR600 and he claims that his first gear is good for about 60mph! Don't know what size his front sprocket is, but the back one is 46 tooth. How can this be? I want to wheelie at 60mph too!:D
See less See more
tommyv, with your sprocket set up you can wheelie in 4th now. 3rd gears at near 100 should be no problem at all. i would start practicing faster, longer wheelies instead of worrying about who can go the fastest in 1st. youll have alot more fun going faster and not to mention it is safer(less chance of looping).
I've tried to wheelie on the highway in fourth. Even tried clutching it, and still no luck, and yes, I was standing up and pulling on the bars. Believe me, if I could figure out a way to get the front end up in third without destroying my clutch, I wouldn't be on here bitching:D
What's the best/easiest way in your opinion to get a wheelie, with my set up, in third? If I figure it out with your help, you just won yourself a case of Budweiser!:D:D:D
I can clutch mine up in third, Just throttle the Shit out of it and pull it will come up eventully.;)
With my gearing I top out at 125. I try not to have to run but if I have to I will. Just have to find traffic and there is plenty of that around here. With your gearing 1 down 2 up 3rd gear should be perfect for you. Definitely will be able to pull it up on the freeway. If your having problems bouncing our clutching it up in 3rd you could always pull it up in 2nd and shift to 3rd real quick.
I think the problem is that there really isn't anywhere to practice doing wheelies, and even if I ride all day long, I might only wheelie three or four times. If more people around here rode sportbikes and were into doing stunts, I would definitely be a happier person:D
I want to get good at stoppies, but don't really want to practice doing them at stoplights and such. I could always find a parking lot, but that would heighten the chances of me getting a ticket. (sigh)
Oh well, if all goes well over the next few years, I'll be making enough money to keep my ninja and buy a 'busa to do wheelies on!
Hahaha. That was a good one.
By the way BTB, I don't have an '03, I ride a '96.
See less See more
1 - 19 of 19 Posts
