The rear axle nut is a 32mm.Taking the rear wheel out is straight forward.Put the bike on a paddock stand. Loosen the nut and while holding the wheel up with your foot, pull out the axle. Drop and move the wheel a bit forward. Pull the rear brake caliper out and over the side of the swing arm.Take the chain off the sprocket and hang it over the swing arm.Take the wheel out. Keep the spacers safe and place them back on the correct side when putting the wheel back.I think the big spacer on the left an small one on the right. To put the wheel back on, basically do everything in reverse order. Try and torque the nut to 108nm.
Keep it mean and green.
