I have a 97 ninja 250, I just want to increase the acceleration of the bike, I don't care much about mpg, I just want the bike to shift quicker, what would be the best sprocket setup on the bike?? I have searched and searched and found different answers... If anybody has a setup on the bike that works, let me know thanks!
OEM sprokets are 14-45
More Acceleration (read below) : 13-45 change front sprocket to one tooth smaller size
In fact, there will be no more acceleration, you're going to put the gear ratios closer together. Aside from that, it's all the same because you end up in 3rd when you would normally be in 2nd. But if you want to shift more often to have the "more acceleration" feel, go ahead and try. There will be a loose of top end speed also..
