i have an aftermarket aluminum sprocket on my rear. my chain slack is fine and my rear wheel is aligned perfect but the inside of the sprocket teeth are getting rubbed down from the chain but only every other tooth. the outside surface of the sprocket looking from the right to the left from the back. the finish is rubbed off and the surface is pretty worn. the sprocket is straight also. maybe the rear tire isnt spaced right somehow. i dont know
I would recheck the sprocket install and ensure that everything is correct. If you had a shop do it for you, talk to them about it. I'm also not a fan of aluminum sprockets for the street. They just don't last very long at all. A sprocket on the street should last at least 10,000 miles in my opinion, if not more. At least the same life span as a chain. Aluminum sprockets are fine for racing since most of the time they only see limited use and will get changed out more often.
Exactly. Stick with steel for the street. The power increase you get is so little worth the time you have to remove and install new sprockets.
