Anyone know wher eI could find sprockets that are like about 20-25 teeth up in the rear? Also its for a 96' yzf 600, the bolt patternns arent the same as the ninja
Nice, they have 72 tooth sprockets for my bike, this will help me pull those 12 o'clock tricks off ;)
You can pull 12's w/ stock if you want to. 12's start off at a stand still and usually don't go over 10mph. Press the rear brake, give it some throttle, pop the clutch. Not a how-to but that is how it is done. Takes alot of practice. I won't be practicing unless I build a bar.
I got mine from Sprocket Specialist but try not to get aluminum because they are cheap and don't last very long (my opinion)
