Originally posted by Jijalicious
Since I'm a Newbie...just like it says over there <- What is the reason you would change the sproket? In other words, what are the benefits? And if they are great, by do you recommend on a '02 6R?
Thanks,
~Jij
Most people change their sprockets to get to their max horsepower more quickly.
You still have the same ammount of horsepower, and it's still the same per rpm (so like 95HP at 12,000RPM, no matter the size of the sprocket) but you will get to that 12,000rpm more quickly then before.
ADVANTAGES:Most common reason people do this is for wheelies, and some will do it for racing. If your on a shorter race track, with no big straights, then losing 20mph top end might not be a bad thing, because you'll be able to accelerate harder out of the corners.
DISADVANTAGES: You'll need to shift more, since you'll be getting to your normal shifting point at a slower speed now. Also as mentioned you loose some speed from your top speed. Since most of us don't ride around at 160mph too often, going to 150 or 140mph top end is no big deal though.
The physical thing that changes is how far thw wheel turns per time the engine turns, if you can understand my patchwork explanation
