So I've got a sputtering problem. I can't take off from a stand still without the bike feeling like it just wants to roll over and die
So I can no longer go up to the front of the line at a light b/c I will be obliterated by cagers when I roll of the line at 1mph. About a month ago I tried cleaning the air filter and sprayed some carb cleaner into the valves at slightly higher idle as the bottle says. Unfortunately this didn't work and I'm stuck like chuck. Once I'm past the dieing phase the bike runs fine. I just miss the pull the bike use to have before this problem appeared. Any tips would be appreciated as my tech level isn't high.
