Re: '81 750 LTD
I was hitting the starter and
"rev/rattle/spin", "rev/rattle/spin", "rev/rattle/spin"
(a rattle like shaking a metal can full of pebbles)
Starter clutch?
I replaced pins, springs and rollers and all was fine - for about 6 months
Then - "rev/rattle/spin", "rev/rattle/spin", "rev/rattle/spin"
I lived with for a while - - just made sure I always parked on a hill in case I'd have to get a rolling start and pop the clutch
But after a while - no more "rev" - just "rattle/spin", "rattle/spin"
Pulled the secondary shaft again, took off the starter clutch.
The 3 socket bolts were loose and stripped
(probably didn't use enough lock tite last time)
Replaced 'em and drowned 'em in red lock tite
Now?
One suggestion is to replace the whole mechanism:
one way clutch, rollers, pins, springs
inner housing
outer housing
rubber dampers
The whole ball of wax
Sounds expensive for a 30 yr old bike
Any thoughts?
Starter clutch?
Now?
inner housing
outer housing
rubber dampers
Any thoughts?
