1 - 2 of 2 Posts
Hi wondered if anyone can help, just replaced the battery and when conecting it all back up as soon as you connect the starter motor it automatically turns over
If the ignition is on the bike does start but the starter motor will not stop
if you connect the satrter motor first it is fine but as soon as you put the negative wire on the motor turns automatically and wont stop
The ignition works fine and the bike will start but then have to take the starter mtotr wire off.
anyone out there know what the problem is or what i have done wrong
Any help will be much appreciated
many thanks Nordy
Hello and welcome!
It sounds like the starter motor isn't hooked up properly, or there is a short somewhere that is allowing it to get constant power instead of momentary power only when the starter button is pushed.
1 - 2 of 2 Posts
