Well, I'd get a TIG welder and weld an aluminum boss to the frame for the one end, fabricate a clamp for the fork on the other, and side mount that bugger. If those aren't options you might do some measuring to see if brackets made by another Damper manufacturer will work. (Expensive... $200+ from Hyperpro)
It's hard to say, but it doesn't look like there's enough travel in the arm to allow a side mount. I'm thinking of the stadard mounting point though, maybe if you go closer to the forks you can make it work. Good luck.
