OK, I'm installing the All Balls Steering Stem Bearing kit right now. Here is the OEM head bearing numbers: NTN SF07A17PXI and here is the number off the all balls tapered bearing kit: KML 32907 and the 2 seals that came in the kit have number 33-1088 on the bag they came in. Hope this helps someone out.
By the way, the installation is easy, but somewhat time consuming as you have to take the front end apart to get the steering stem out. The outer race's that are in the frame came out in about 30 seconds. There is a spot in the frame to put a punch to drive them out. The hardest part was getting the lower bearing off the damn steering stem without damaging the surface
