Anyone got a good how-to for this. Maybe step by step stuff? Bad enough I don't have a front stand to do it. I'm gonna have to hang my bike from the ceiling.
Dan...comfortable enough with his manhood to ride a 600.
Why would you need a front stand to tighten the steering head ? Why do you want to tighten it ?
it's very easy.
you loosen the 4 allen bolts holding the clip on handlebars, not remove just loosen.
then just like making an adjustment for your "sag" you have 2 toothed rings.
loosen the first one and then tighten the second one.
then tighten the top on andthe allen bolts for the clip ons.
There is a special tool that would be in handy otherwise use a flat head screwdriver and a small hammer. Sorry I forget what those toothed rings are called.
WMRC Novice Racer #87
www.bcsportbikes.com/cgi-bin/bike.disp/37
I heard you have to take off the weight from the front tire to tighten them properly.
Mine are lose so when I stop I can feel the forks shake a bit. Not to mention during stoppies my bike tends to swing around.
you should fix it asap....if the bearing is as loose as you say it is,it will wear out quickly...and it can headshake...
I have replaced the bearings on mine a year ago (landed real bad from a wheelie). You don`t have to raise the front, but I`m pretty sure you will need to remove the upper triple clamp, though...
go green or go home!
