Yeah i agree u really can't go off someones else settings get u'r sag set front and rear and play with and test your self as everyone rides differently and prefers different settings, just an idea but the stock set up is pretty good maybe soften both comps a little depending on your weight as i found it a little stiff.... but i'm only 80kg....
Front
Spring preload-3 lines showing
Rebound damping-2.5 turns out from full stiff
Compression damping-1.5 turns out from full stiff
Ride height-6mm fork tube showing above triple clamp
Rear
Spring preload-2 threads showing
Rebound damping-14 clicks out from full stiff
Compression damping-0.75 turns out from full stiff
i'm 5'11'' 185 with out full suit. never weighted with one on
