1986 klr 600 b new mag ,new coil ,new pulse pick up coil, new cdi still have no spark ,,,My question can u leave the white wire disconected on the cdi to rule out the on off switch kickstand and neutral switch ?
any input would be appreciated
thanx jon
I would leave all wires correctly connected. Figure out how to bypass switches. Troubleshooting these CDI bikes from the 1980's can be difficult. Too many mystery components.
Is there a pulse from the pickup/exciter coil? Just disconnect the BK/Y and BK wires and connect to AC Voltmeter. I have no idea what it should read, maybe 5-10 VAC at kickstarter speed??
Schematic Font Parallel Rectangle Engineering
i found this page in my manual ive tried to follow each wire ,,,,it looks like the previos ownner took a hachet to wireing harness deleting turn signals kill switches and god knows what ill check pulse coil for voltage
thanx for info
jon
Not voltage , only a signal when the magnets pass the pick up coil . Check the manual .....
found out that the aftermarket ignition switch i got / even though it plugged right into the wire harness had a n/c and n/o and a power circuit - the middle and right set of wires in the jack were reversed so every time i cut the key on it was killing the bike --switch them and all is good
thanx for your help
jon
