The cams will not interchange . In 2000 when they went to the new head design the journal diameters were reduced .
The 98-99 model had advertised intake duration of 316 vs 300 for the 2000-up models . Both exhaust duration were the same @ 292 advertised . The actual timing events were different both intake and exhaust and the early models LCA's were 103 intake - 99 exhaust vs 105 intake - 100 exhaust for the 2000 up year models .
The 16 degree's of advertised difference in the two intake cams does not mean the early models were " hotter " though and as far as lobe intensity goes , I'd believe the later model intake lobe to have the higher actual lift rate and potential gains in low lift flow of the two . They improved the head in 2000 , I'd like to think they did not step backwards on the intake cam .
