hi
i have rounded of the allen bolt :mad: that you need to remove so i can put on crash mushrooms...anybody got any ideas on how to get these out...
thanks
stealth ( uk )
get a bolt out. Going to look like just a round head that will have grooves/teeth semi vertical. You will just tap it into the allen head and use a wrench. You can get them male or female depending on whatever bolts you are trying to get out. but basically it just grips the shit out of the bolt and busts it loose.
Second concern - when you put the new bolts in.....use the right allen head socket.
either use an easy out, or use a dremel or 3" pneumatic cutoff wheel (or a hacksaw or sawzall if you're good) to cut a slot for a screwdriver (or an appropriate size) in the head.
a little heat never hurts, either :)
good luck!
