Originally posted by ninja_s
disounts for track riders sounds very good. what becomes of the situation when you sign up to use their bikes and you end up crashing?
I'm a coach at the California Superbike School. If you crash one of our bikes this is what happens:
You put down a $750 damage deposit which is returned if you don't damage the bike. The most you are liable for is that $750, so if the bike happened to burn to the ground you are only out $750 at the most.
If there is slight damage, such as a minor lowside, you get charged 10% BELOW dealer's cost for the parts and NO LABOR. Aftermarket plastic is used, so a full fairing replacement costs only about $200. And if it can be repaired (filled, sanded and repainted) the cost is less.
We average 1.5 crashes per 100 riders. Of those crashes, better than half are from a guy running off track and tipping over in the grass at very low speeds.
