So, took my sag measurements today. Front is 35 mm and rear is 40 mm. (Not sure if this is static sag or what, but it's the total sag from the suspension being fully extended with no weight on either end and with me on the bike in the riding position with my full gear on.)
I weigh 200lbs and would consider myself more of a conservative rider. (no track days or aggressive twisty riding.)
Should I increase the preload on the rear shock so the sag goes down to 35 to match the front? Do you have to match the front and rear sag. I'm pretty comfortable with the current settings on the suspension, but then again, I'm not a real aggressive rider so I'm not pushing it.
Also, I checked the preload settings on the fork and found that they are both set at 10 turns counterclockwise from fully clockwise position. I'm a little confused because the service manual says the fork spring preload setting is 5 turns from the fully counterclockwise position. (which matches what I found.) But the owners manual says the preload is 5 turns in from the fully seated position. (which seems opposite to what I have.) My understanding is the preload is the hardest when screwed in and softest with screwed out. (righty tighty, lefty loosey) So does this mean that I can turn the preload adjusters ten more times clockwise to make the preload stiffer?
