This should be an easy one...
My last bike had a center stand and there was no need for a swing arm, if I get one is there anything else I will need (other than what it comes with brand new) in order to start using it? Also, any particular brands I should look for?
They come in two flavors. The ones that use spools and the ones that use pads. The spools bolt to the swing arms in those two holes near the rear axle on the bottom side of the swing arm. The stand lifts by the spools. I think the ones that use spools are less likely to slip. The ones that use pads have to adjustable pads that fit under the swing arm.
Being cheap, I made one out of a discarded grocery cart that works just fine.
I think a Pit Bull stand goes for about $100.
