Is all that foam in the tail really necessary? I just got a new tail and the foam is not in it. Tried remove foam from my original and couldn't. Is is in there for heat disspation? or sound?
Probably a little bit of everything. Sound dampening, vibration reduction, heat shielding from the undertail exhaust. You will probably be fine without it. Put it on, ride the bike and see if you notice any difference. If you do, order the foam and stick it in, if not, you are good to go.
