I recently did the euro wire modification, installed a Speedo healer, and a gear indicator. Now the temperater reading on my console is about 30 dergees higher than what the temperature is at my radiator. I undid the wire mod to see if that would fix it, but it did not seem too so that leads me to believe that it is either the gear indicator or the speedo healer. anyone else having this problem?
The only way that the Speedohealer would do that was if you hooked into the wrong circuit. The speedo sensor on the 05/06 636 is on the back of the tranny. Make sure you hooked into the right sensor.
I just did the wire mod on a buddies 05 636 and it is running fine with no difference in temps.
Powerhungry
yep, or u tapped into the wrong color on the gear indicator. i did that the first time. ones a blue, and a light blue wire. i dont remember which, but one is the temp wire. OR...u accidently switched it to
celcius(sp)??
