ZX-6R/ZX-6RR
Type
4-stroke In-Line Four
DisplacementOverall drive ratio
6.223 @ top gear
Clutch
Wet, multi-disc
FRAME
Type
Perimeter, pressed aluminium
Suspension
front
41 mm inverted cartridge fork with adjustable preload, stepless rebound and compression damping and top-out springs
rear
Bottom-Link Uni-Trak with gas-charged shock, stepless rebound and compression damping, spring preload adjustability and top-out springs
Tyre:
front
120/65 ZR17 M/C (56W) T/L
rear
180/55 ZR17 M/C (73W) T/L
Inflation:
front
250 kPa {2.5 kgf/cm2}
rear
290 kPa {2.9 kgf/cm2}
Caster (rake)
24.5°
Trail
95 mm
Steering angle (left/right)
27° / 27°
Dry weight
161 kg
BRAKES
Front brake
Dual semi-floating 280 mm discs
Front caliper
Radial mount opposed 4-piston calipers
Rear brake
Single 220 mm disc
Rear caliper
Single-piston caliper
ELECTRICAL EQUIPMENT
Battery
12 V, 8 Ah
Headlight (high/low)
12 V, 55/55 W x 2
Tail/brake light
12 V, 0.5/3.8 W (LED)
PERFORMANCE (ZX-6R)
Maximum power
Maximum power with Ram Air
87 kW {118 PS}/ 13,000 rpm
91.5 kW {125 PS}/ 13,000 rpm
Maximum torque
67 N·m {6.8 kgf·m}/ 11,000 rpm
636 cm3/599 cm3
Bore and Stroke
68.9 x 43.8mm/67.0 x 42.5mm
Compression ratio
12.8:1/13.0:1
Valve system
DOHC, 16 valves
Fuel injection
Ø 38mm x 4
Ignition
Digital
Starting
Electric
Cooling
Liquid
Lubrication
Forced lubrication, wet sump
Engine oil:
Rating
API SE, SF or SG, SH (with JASO MA) or SJ (with JASO MA)
Viscosity
SAE 10W-40
Capacity
4.0 litres
Spark plug
CR9E
Piston clearance
0.010 ~ 0.037 mm
Cylinder pressure
1,350 kPa {13.8 kgf/cm2} @ 350 rpm
Exhaust
4-2-1
DRIVETRAIN
Transmission
6-speed, return
Primary drive
Gear
Final drive
Sealed Chain
Primary reduction ratio
2.022 (89/44)
Gear Ratios:
1st
2.923 (38/13)
2nd
2.055 (37/18)
3rd
1.722 (31/18)
4th
1.450 (29/20)
5th
1.272 (28/22)
6th
1.153 (30/26)
Final reduction ratio
2.666 (40/15)
I had them on disk
fear is like sex everyone needs it everybody wants it sometime in there life
