OK, seriously, it sounds like shit, but I wanted to grab your attention. You're looking at an 06 that has less than 1300 miles. The valves have been adjusted and the CCT has been swapped with a verified good / working one. Anyone want to share some insight into the possible causes? The engine runs and revs fine, but the clacking persists. The old "hand dyno" also indicates that I have full compression in both cylinders (exhaust is coming out with equal force both sides when I put my hand in front of the pipes.) I can't isolate the noise to one specific area, even using the old screwdriver method, because it is resonating throughout the head. I can say with some certainty it is not the valves at the top end because I can hear them chattering away when I get really close. I'm going to end up pulling the engine and tearing down the top end at the very least because I suspect it may be a bent valve stem causing the valve to slap against the piston, so don't be afraid to say "you're gonna have to tear down the engine..." All input is appreciated!
Nope, as I said, I already swapped it out for a known and verified good one. I also on a whim hooked up the original one I took off it to my 07 and it works just fine. If only it were that simple....
do a compression check with a gauge and see if one cylinder is way off from the other, if you suspect a valve is bent.
