Throttle Cable Bracket keeps getting stuck
163 Views 5 Replies 4 Participants Last post by  JustAJ
Just rebuilt my ninja 250r carb. I replaced installed it. Every time I pull the throttle the bracket gets caught. I can force it over but obviously it shouldn’t be doing that. If anyone has any advice please let me know
A Picture of what your referring to would help ;)
The Bracket the holds the push and pull cables gets caught while pull the the throttle
bracket has been snapped/repaired (see yellow circle) should be 1 piece. The angle at which it was repaired is obviously incorrect. Get a new, unmangled bracket.
Automotive fuel system Automotive tire Hood Motor vehicle Tire
See less See more
  • Like
Reactions: 1
You also seem to have way too much slack in those cables. Tighten them up. You should only have about a nickle's width of play at the bar.
  • Like
Reactions: 1
