hmmmm......not too hard. remove the tank and the airbox first (makes it easier), then remove the entire clip-on, trace the cables to the engine where they twist the throttle, then you can either remove the entire throttle cable bracket assembly or the cables indivually..though removing the entire thing is better.
mine is a 96 but i think they're pretty close
so i snapped that little bracket the cables attach to... well one side of it... what should i DO? can i replace just that bracket or do i have to replace the rod also that goes all through i think 3,4 cylinder carbs.?
it would go through all four i guess...damn! how did you break it?
anyway you should be able to get just the bracket. it's a circluar thing right?
spring behind it?
Discussion Starter #6
hmm... so how do i take this freakin thing off?!?!? I can t figure it out. is it a press fit?? DO i need to replace that whole shaft or something?
