1 - 9 of 9 Posts
I just picked up my 2005 zzr600 about two months ago, and noticed I can hear a light ticking noise at low RPM. I can't hear the ticking once the RPM's get up there, but that could be because the exhaust noise drowns it out. A buddy of mine said it might be carbon deposits on the valves, but the bike only has 2600 miles on it. I wanted to see what you all might think the problem could be and if it could be serious..... I don't want my engine or valve train getting screwed up for something that I could fix myself or have a mechanic fix for under $200.
Do a search on this..but I'm pretty sure it's a normal thing. My 2006ZZR does the same thing, and have heard this from several others on here.
sounds like valve clearance tick, mine does it too. I would not worry about it cause the 1st valve adjustment is at 7500 miles. Mine has had that tick since I can remember and now im at 6700 miles.
That's good to know, I've talked to some coworkers who've owned Kawis before and they all say it's normal too. Thanks for the info and at least now I don't have to think my engines gonna tick itself loose.
Even the 00-02 6R's had a ticking sound from what I understand...mine makes it too.
Mine ticks and it also makes a slight knocking noise when coasting (while letting the engine slow the bike down). So I took it to the dealer and they said that my bike sounded really good, better than most, and told me that they are noisy engines, but pretty much bulletproof.
mine also ticks,, had the valves done at 14000, no valve problems and it still does it now at 25000, I am almost sure all of them do it.. normal
1 - 9 of 9 Posts
