If you didn't change the filter, you have 1.4 lites too much. You can just undo the drain plug and bleed some out and put it back in quick. Otherwise the bike smokes since the excess oil backs up into god knows where, which can't be good.
JackOriginally posted by sgates
No need to do that. The small amount of oil in there is a non-issue and not worth the effort to remove. No need to complicate the oil and oil filter change like that.Originally posted by Strong Bad
For a proper oil change be sure to remove the heat-exchanger as well.
