Is this in the owners manual? Or does anyone know the exact torque specs for the headers? I am installing a Full Leo System next week and want to be be sure that I don't over-tighten.
Thanks.
it is listed in the service manual, not owners manual.
off the top of my head, i believe its 15ft/lb
i just looked at the service manual... I think it says 13... But im unsure which one it is talking about. Exhaust manifold Holder nuts right?
Veteran Lowsider
Heres a walk through by leovince for the full corsa exhaust, but the same steps are required but maybe the tail mounting and some hardware
https://www.leovinceusa.com/instructions/large/IM-7907-GB.pdf
You will need a spring puller to get the exhaust springs on, buy it in advance
torque is 13 ft pounds, dont forget to put the copper exhaust gaskets on the header's pipes
what did you end up doing with the exhaust butterfly valve cables when you installed yours? Do i just remove that cables and keep the actuator intact?
Discussion Starter #6
Nevermind i figured it out... i just remove the cables from the servo... no need to get the Ivans servo eliminator... pretty cool... Thank God for reading the Ivan's thread.
