anyone know anything about the sub throttle actuator, what would make it faiL? my friend had his bike washed and afterwards a code 62 shows up which is the actuator. I just don't understand how alittle water would ruin this part especially when the bike only has 3k miles on it. I read in another thread where a guy mentioned if you are able to move the throttle plate rod while the bike is running then that means your actuator is done is there any truth to that????
There you go.
Service Codes FI Indicator Light (LED) Problems
11 Main throttle sensor malfunction, wiring open or short
12 Inlet air pressure sensor malfunction, wiring open or short
13 Inlet air temperature sensor malfunction, wiring open or short
14 Water temperature sensor malfunction, wiring open or short
15 Atmospheric pressure sensor malfunction, wiring open or short
21 Crankshaft sensor malfunction, wiring open or short
23 Camshaft position sensor malfunction, wiring open or short
24 Speed sensor malfunction
31 Vehicle-down sensor malfunction, wiring open or short
32 Subthrottle sensor malfunction, wiring open or short
34 Exhaust butterfly valve sensor malfunction, wiring open or short
35 Immobilizer amplifier malfunction
36 Blank key detection
51 Stick (Ignition) coil #1 malfunction, wiring open or short
52 Stick (Ignition) coil #2 malfunction, wiring open or short
53 Stick (Ignition) coil #3 malfunction, wiring open or short
54 Stick (Ignition) coil #4 malfunction, wiring open or short
62 Subthrottle valve actuator malfunction, wiring open or short
63 Exhaust butterfly valve actuator malfunction, wiring open or short
There you go.
What code is 71... i got 7 long beeps then 1 quick or 2 but im betting on 1. This code pops up when i hit my rev light comes on or maybe it was just at the same time, and then my throttle gets stuck and runs about 3-4k rpms. If i shut the bike off and pull key out then back it the code clears and throttle is fine. Was thinking about just swapping out the whole throttle system anyways get new cables and all that but mine works fine most of the time. Also this is something new never happened b4 till this yr.
You need to at least tell us what Model/Year Bike as the 05-06 doesn't go up to 71 ;)
