Sometimes I find it hard to shift to nuetral from first. Like I will be at a light at a dead stop and go to shift to neutral and go to second, its really annoying.
do you ever adjust the choke after the bike warms up. I had the same problem, I f I adjust my choke to idle at 1.5 it goes away. UI let it warm up to 112 degrees at full idle after the warm up lower it to like 1.5 and it will stop.
It is a pain in the ass
Actually I shift to neutral only at full stop. So it's almost never any problem. I found it harder to shift to N on F4 though. Maybe you should look how the shift lever is adjusted. Try a search.
I have a little trouble getting into neutral when the bike is cold, but after riding for 10 min or so, it becomes much easier.
Sometimes when I'm stopped and shift up to neutral (using positive neutral finder) the bike's neutral indicator flashes on then off again - but it is in neutral - if I let out the clutch, the light comes back on. Are you sure you're in second, or is the light just off? Try letting the clutch out slowly and seeing if you pull forward or if the light comes on...
when your at a light and in first gear, ease out the clutch slightly until you find the friction zone(it moves a little) then you can lightly shift in to neutral. in the msf they recomended you shift into neutral after the bike is off.
