1 - 2 of 2 Posts
I installed the lowering link today which lowered my er-6n 1 1/2" but then the suspension coil was hitting the frame and chafed when I sat on it :/ Does anyone know if I need to lower the front a little bit to fix that or can it just not be lowered that much? Thanks!
Yes you should lower the front, but that is not going to keep the spring from rubbing. Try grabbing the spring and rotating it so there is no coil next to the frame.
1 - 2 of 2 Posts
