I just bought a used 2009 Ninja 250. I took off one panel to access the air filter just to inspect it as I was curious. I put everything back and the next day I noticed my right turn signal wasn't working in the front. I thought it was a bulb so I swapped bulbs and it still wasn't working on that side. I found out I nudged a cable and noticed the connector was patched in the past, and wiggling it makes the turn signal either work or not.
My question is, what will I find when I take off the electrical tape, and it is an easy fix or replacement?
Thanks.
Pics:
https://www.dropbox.com/s/v3zxc5sk6a3tssr/Photo 2013-09-13 3 33 06 PM.jpg
https://www.dropbox.com/s/zr851t6zd8oah4r/Photo 2013-09-13 3 33 35 PM.jpg
actually due to the wire size u need this one. also use a lighter on the end of this connector for a second and it shrinks down and makes a water tight seal to prevent corrosion. i use these all the time. literally they work great
