anyone had problems after changing the stock signals for aftermarket signals,i have heard that some people have had very fast flashing signals after changing them,im gonna change mine this week so if i experience this problem i will piss all over them.
"160 mph officer, i have only been out 5 minutes".
Depends on the bulbs the signals come with... test connect and try them before you bolt everything together. That way if you need to change the bulb wattages it'll be a little easier.
The LP flush mounts and shorties gave me no problems [^]
[:p] '02 Green ZX-6R Limited Edition [:p]
If you are just changing stock signals for aftermarket signal you most likely will not have a problem with fast flashing unless you have LED bulbs. Most of the problems with fast flashing involve the installation of a rear tail light integrator.
I put the LP stick-on flushmounts for all 4 signals and all signals were blinking fast. I just changed the turn signal relay and they flash at normal speed now. The relay was like $9 from Pep Boys/Auto Zone. It's a quick fix if your signals are blinking fast.
02 zx6r
94 z28
