My turn signals stopped working yesterday. The indicator on the dash doesn't work, and none of the actual signals work. I haven't yet checked the fuse, but was wondering if anyone else has experienced this problem.
TIA.
check the fuse. are they aftermarket signals? maybe you installed them half ass? if not take it back to the dealer and say, "i dont know what happened"
Originally posted by samps
Turns out it was the fuse. Weird...I replaced it, and then it burnt out again right away. It seems to be ok now.
If it burnt out right away, you should check all the wires. Cause there might be a bare spot in the wire which could be touching some metal, causing it to blow the fuse...
Discussion Starter · #7 ·
It was the damn aftermarket lights. I hate it when products aren't made well. It seems to be fixed now. I replaced the front blinkers with Rumble Import carbon-look ones.
Simpson
