1 - 13 of 13 Posts
Well, after struggling to get the midpipe onto the collector, I finally realized I should remove the rearset and that black plate around it. Then it slipped right in. When I started it up, I felt a leak around that midpipe and collector joint. I followed the Two Bros. install instructions and removed the stock gasket and placed a bead of silicone around it before putting them together.
Anyone else have this problem? Did you reuse the stock gasket at the collector joint? Maybe I just have to remove it and try again (was pretty frustrated with it and it got late). I'll check it again tomorrow. :(
Discussion Starter #4
I almost stripped it (couldn't get a straight shot on it with the allen). I finally put just the tip of the allen in and banged it with a hammer a few times before putting the ratchet on. I got it off without stripping it but I almost just drilled the damn thing out!
Discussion Starter #7
C'mon guys - hundreds installed this slip-on...what did you do? It would be nice if the damn header didn't have slits on it...
Banned
I took the whole header off and bolted it on to the slip on then put in on as one piece, i was getting so pissed!!!
but i got it
im in the same boat right now, i got it all together and the imfamous hole on the mid pipe didnt line up for me either.
i got it all together and fired it up and noticed a pretty major exhaust leak from the collector. i did remove the rearset and that access
plate but still had a bitch of a time. im gonna tackle it again right now with hope that i can seal it up. bump for another leaky collector!
Originally posted by joejoe0187
I'm calling those fuckers again on monday and telling them I want a new midpipe for free.
Honestly, the instructions that comes with the 2bros is so clear and well explained, if you fucked it up you must be a retard not so mechanically minded person...no fault of 2bros anyway :D
The instructions do not mention removing the black panel that covers the swingarm cutout.
I had a very hard time getting that panel's bolts out (after I realized that it had to come off).
i put a lot of the silicon on mine to make sure but everything works fine. i did scratch the hell out of the pipe though trying to get it on before taking the rearset off.
1 - 13 of 13 Posts
