Using the Clutch
  • All the time
    Votes: 0 0.0%
  • Only to Down-shift
    Votes: 0 0.0%
  • Only to Up-shift
    Votes: 0 0.0%
  • Sometimes alittle for both
    Votes: 0 0.0%
  • What's a "Clutch"?
    Votes: 0 0.0%
1 - 12 of 12 Posts
Ok here's just a simple question. Besides stoping and starting, how much do you use your clutch?
Discussion Starter · #2 ·
Personally I use it more for down-shifting and hardly ever for u-shifting
I sometimes don't use it to down-shift, get the rpms right and it slides right into the lower gear without even a "clunk" but very seldom do I get it without the "clunk"
All the time. Its a street bike that I am riding on the street. Why put more stress on components than needed? If I was riding on the track, then I would probably only use it for down shifting but then I would have also added a quick shifter.
I use the clutch shifting 1-2( depending on take off ) and 1-N( when parking or at a long red light)....I seldom use the clutch to down-shift..i just blip the throttle(very quickly) and a lil bit of preload and it sounds just like a speed shifter and doesn't upset the bike at all....TIMING IS EVERYTHING.
depends on my mood really. besides, i thought they put the clutch on there for wheelies:D
Normally only when trolling thru traffic.
Other than that, I hardly ever use the clutch.
It's so much smoother when you time it right.
+1;)
ratherberiding
i go clutchless when i'm walkin the stiff diagonally behind me, his clutched shifts slow him down....otherwise, i use the clutch
1 - 12 of 12 Posts
