Does this make any sense?
The shop manual lists 45* for the primary valve seat surface. Also has listed a part number for the cutter. However, at the shop all they had was a 46degree cutter. He told me (the service guru), "yeah, you don't cut a 45* seat with 45, you use a 46*. Otherwise your valves would slam every time they closed."
Here's the question.
What angle valve seat cutter do you use for the 45* seat surface?
