Hi everyone.
I have had my 2003 636 B1H from new, a whole 5 years of fantastic Kwak fun. I was over in the Isle of Man TT this year and the bike started with a bad vibration when braking (front brake) The harder you pull the brake lever it goes away, bit weird. I had a chat to another guy that had the same problem, he was told it was possibly the front forks? Could this be true and if so what needs doing to them? The brake pads and discs are fine. Thanks in advance.
Al.
i would generally start by checking the Disc's and Brake pads and making sure everything is nice and tight for bolts n such.. if you have done this maybe get your brake disc's checked to ensure their thickness is right and that they are true and strait. not sure about what problems the "forks" could play on your braking issues...
