Hey everyone - I assume all modern Kawasaki’s share a similar wiring loom, so I thought I’d come here.
I have a ‘20 W800 Cafe and decided to do a fender elimination which meant ditching the OEM incandescent brake light.
I clipped away one red, one blue and black wire with yellow stripe from the housing. The black one with a yellow strip was connected to a grounding tab.
The replacement, a new flexible LED strip is an all in one running/brake and turn signal which I tested on a 9V battery, it works as advertised.
I assumed the connections would be 1:1 but I’m getting nothing, I’ve checked the rear loom with a multimeter, all voltages good.
I know it’s gotta be something simple, maybe I need to connect the ground wire to bare frame?
The LED has 5 wires:
Black - I assume ground
Red - Brake
White - Running
Green - Left Signal
Yellow - Right Signal
I’ve connected like this
W800 Loom LED Loom
Black w/Yellow Stripe to: Black
Blue to White
Red to Red
Nothing is working, again tests fine on a simple 9V battery.
Thanks all!
Bicycle tire Bicycle handlebar Electrical wiring Computer hardware Bicycle frame
Bicycles--Equipment and supplies Bicycle handlebar Bicycle tire Bicycle frame Automotive tire
