Well one month after my factory waranty has expired my water pump started leaking from the weep hole. Not a constant drip but maybe a drip or two every day. So I ordered new seals for it and decide to fix it before it leaks bad. Well now that I have replace the seals it leaks worse than it did before. Like 10 times worse! Nedless to say I am pissed! I have taken it apart several times to try and figure out if I screwed anything up but all is as it should be. No worn parts. Nothing. It only has 5400 miles on it. Before I order two new seals ( maybe got a defective mechanical seal ) I wanted to know if anyone has had this problem before? Is there anything in particular I should look for??????
