finally fixed the carbs and everything on my bike. Just replaced the o-ring that goes from the bottom hose to the water pump, still spewing antifreeze... Is my water pump bad or could it be too much antifreeze or something getting stuck... I am really annoyed because I just replaced the o-ring thinking thats what was making it leak..
The Indifference Engine
You need to find the source, not ask us what it could be. Clean it up, then trace it back until you find exactly where it's coming from. Ask yourself why that could be leaking and fix it.
its coming exactly from where the pipe on the bottom connects directly to the water pump, i think it may be the seal not setting or something. I just don't know why it would be doing this because I just put a new seal, and its still leaking.
Discussion Starter #4
I found a missing bolt holding that pipe to the frame, I replaced it and theres no leak. I just hope this fixed it.
