1 - 8 of 8 Posts
So last weekend I tried to switch pver to GP shift - thought I had to get the spindle exactly 180 degrees from stock. Tried to move the gear shifter spine coming out of the tranny to have a better chance of getting the screw back in place. The gears kinda got stuck between first and second, so I decided to move the bike to the middle of the garage and put it on the rear stand - as I was moving the bike, with the gears still not in neutral, I heard what I thought it was the tranny ticking between gears - the ticking was present even with the clutch pulled in. Decided to just get the bike into neutral and back into stock gear pattern.
So today I decide to go for a short ride, less than 30 miles, and when I get home and pull into the garage, I turn off the bike before turning the bike around to get it into the proper area of the garage - as I am moving the bike around, I notice a ticking sound coming from the lower rear section. I put the bike up on a stand and started to spin the rear wheel and got the tick to sound as I rotated the rear wheel in either direction. I looked to see if anything was rubbing against the chain, bit did not see anything. I could kinda feel the ticking with the hand that was spinning the rear tire. The click sounded about every three inches the chained moved.
Questions:
Did I mess up the tranny by moving the bike with the gears not fully engaged or in neutral?
I did lube the chain last week, but could the chain make ticking noises if it is worn out? The stack seems correct when measured.
Any suggestions on what I should check out to prevent damage?
Does it sound like it's coming from the chain or from the tranny?
That Fighter Guy
Chain may be too tight. Slack needs to be 1 to 1.5 inches with the bike sitting on a rear stand without a body on it.
Discussion Starter #4
The chain slack seems to be set correctly - tested it in several spots; but could still be a possibility.
The sound definately sounds like it is coming from the rear sprocket, chain, or hub area - I use a mechanic stephoscope and could not hear anything internal making any sounds - which was a relief.
The Indifference Engine
Are you sure the rear wheel is square in the swingarm? If it's not evenly adjusted it'll side load the chain which makes a loud clicking ticking noise as each individual link comes off the sprocket.
Discussion Starter #6 (Edited)
Mystery solved - Good call Sev - it was the rear tire not being square in the swingarm. The way I was looking at the right side indicators on the swingarm made it appear that they were even - as soon as I sat down right in front of the right side to take some exact measurements, it was obvious that the right side was off a couple of mm. Made the adjustment to make everything square and the noise went away.
Thanks for the help - I can finally fall asleep again without wondering about the noise.
Wouldnt you feel that while riding if the tire wasnt centered correctly?
1 - 8 of 8 Posts
