last week i started my bike, i rode it like 2 days before, was running
well, and it fired up and running fine, then before it was totally warmed
up i was tooling with the throttle gassing it up, waking up the
neighbors. while i was gassin it, the bike seemed to bog out and then it
died and i couldnt get it started again.
i replaced the plugs, reconditioned tha battery, checked the fule filter
and the fuel pump. she finally fired up today, after going over everything
again. and getting the battery reconditioned. so after i let it run a
little bit, it was sounding like all 4 cyclinders were not firing, the
bike sounded weak. i have a muzzy exhaust and it sounds like a tiger
purring not a allycat! so i felt the pipes of the exhaust for each of the
cylinders and only 2 of them were warm.
so i figured maybe all the plugs were not connected properly, so i went
through and checked them all! they all seemed to be good. what i have to
do is check each plug for spark, cause i didnt do that, i only did 1. im
thinking if the 2 plugs on dont spark then the coil is probaly gone
bad! if its not that, then maybe the carbs are mucked up!
i didt check one of the cylinders that seems not to be working and i
noticed some oil inside the plug well, not sure what that is , but it is
somewhat disconcerting. this is about all i have done. i dont know what
else i should do!
modern man
eco system destroyer
else i should do!
modern man
