1 - 8 of 8 Posts
i recently bought a full akrapovic exhaust system for my 2001 zx6r and was wondering which jet kit works the best for the 4 into 1 system, im going to do the install myself and was leaning towards an ivans or factory pro, any help would be greatly appreciated
I've read good things about both. I myself would lean towards the Ivan's kit, especially if you're doing it yourself. You just call in your order and speak to Ivan personally I hear. Tell him what you have and they'll ship you out a kit that's set up with the best needle heights and jet sizes and ready to be dropped in.
sweet thanks for the help ill see what i can come up with, also when i do this is carb synching required and if it is can this be done myself and what does it consist of
both factory pro and ivan's have technical support. i personally have a factory pro kit and i love it. your goiog to get excellent results with either its just takeing the time to tune it correctly so i would set aside a weekend to work on it. also find a local shop that has a dyno with a/f ratio.
that way when you get it where you like it you can take it in to get dynoed then fine tune from there.
ivans site said it was designed for the akrapovic 4 into 1 exhaust so ill probably go with that one instead of factory
1 - 8 of 8 Posts
