Hey guys I just bought a 1996 ZX6 with 3,000 miles and supposedly rebuilt carbs and everything. My question is first, the guy i bought it from said he ran premium since he had bought it (wasnt the original owner) and so i filled it with premium. Well, the bike has a little bit of a hesitation problem when holding the same rpm for a while, like cruising at 5000 rpm, the bike will load up a little bit, then clear out, then load up.... etc... if i punch it when its loading up it has to clear out and then it goes like normal. So I'm wondering if using the 93 octane is perhaps hurting more than doing good? I've heared that running a higer octane than recommended can actually do things like that... And I don't have the manual around to look up the recommendation.
I'm planning on also adding some sea foam to see if that helps too....
